Search Forums | Classifieds (57) | Skins | Language
Hydraulic motor return
pmartens07
Posted 5/29/2021 07:10 (#9031021)
Subject: Hydraulic motor return
Penn Yan, NY
Have 2 separate systems on the planter using hydraulic motors. Vacuum fan and 2 variable rate motors use about 12.5gpm and the dry fertilizer blower uses 6gpm.
Iā€™m having heat issues
Planning to put in a hydraulic cooler and plumb the returns into a free return. Tractor has a 3/4ā€ male pioneer for free flow and a 1/2ā€ flat face for case drain. Can I T the 2 case drains together and 2 free flow returns prior to the tractor? Would like to use quick couplers at the T. Should they be flat face or is pioneer ok? Want to minimize restriction and heat.
Hydraulic cooler is supposed to take of up to 50F
