Posted 9/2/2018 09:22 (#6964759 - in reply to #6964283) Subject: RE: Claas Jaguar 900 power problem update
W IOWA
Check to make your sure your gearbox on your silage head is set to the right length of cut to match your feed rolls. If they're not synchronized they will make the auger slip. Could be the slip clutch is going bad too. Does your chopper have the capability to synchronize the feedrolls in the computer.
