South central kansas |
"Wonder if the usda is trying to overstate supply in case all hell does break loose? Kinda of a calm fears tactic."
If all does break loose as you say and it goes nuclear, I doubt you have to worry about the USDA overstating supply, because you'll have a lot less mouths to feed and with that most probably comes economic collapse with the countries affected, depending on where exactly it impacts.
