NC Ohio | Colley - 3/21/2017 12:20
What kind of scale is on the 352? I've got a 352 that grandaddy wore out 3 times then upgraded to a 354, I grind small batches all the time with a play form scale & 5 gallon buckets.
I have no clue what scale it has, I can check later if you would like.
When I say small batches I mean 300-500 lbs, I usually grind around 1 ton at a time. All of my corn comes out of the crib or a wagon, so using a platform scale isn't very easy. |
