Eastern, NC | Like wire farm mentioned larger machines typically cheaper for the weight and power. But you run into having to get over weight permits, Using Tri axle trailers and or trucks, and permitted routes. Or at least that's the case here In NC. If you didn't have to move it but few times a year I would hire it done. 35k-55k lb machines are good working machines but with construction in NC hot there's no deals to be found in them right now. | |
