NW Central Ohio | ..I just repaired the tube on my 70'x10" Hutchinson. You need to find a piece of like sized tubing that extends past the rusty area and sleeve it around the outside. A patch is OK.....but not my favourite way to fix one. My older Mayrath 8" has the hydraulic swing auger drive. On our older IH tractors...you never need a by-pass...because the maximum pumping ability doesn't overspeed the swing auger.On my newer MXM tractor, I had to use the flow control adjustment on the tractor to slow it down so it doesn't throw grain out of the hopper and overfill the main auger. A needle valve installed between your hoses with T's would give you some adjustment if you need it. I would try it with grain in it first before messing with it though. By the way...if you're taking the bottom end apart...buy a new piece of flighting and replace the bottom 3' of flighting on the main auger. It will most likely be knife edged by wear at this point.
Edited by pupdaddy12003 11/7/2016 07:10
