Posted 10/20/2016 21:24 (#5592251 - in reply to #5592072) Subject: RE: 8245r goes through a lot of fan belts
Moreauville LA
I bet when you changed the belt you said, "Seems like that side is worn more than the other."
Likely your splines are gone on the inner sheave and is being driven by the outer bolted sheave. I also bet your tractor has heats up real quick, then cools off and the fan surges.
BTDT
Gat a new sheave, the three red o rings for the pistons, a new boot and another belt. 30 minutes later it'll be like new.
