roaming | precisionIH - 5/23/2016 09:57
Installed a NAVll, Pro700, and 372 on 435 Stieger. The orientation of the NAV is in the correct position as far as mounting goes (fins up and cables pointed towards drivers seat.) The display gives an error message saying the vehicle can't engage going in reverse but it allows you to create a guidance line. I even tried rotating the NAV and it constantly shows the tractor going East. Any ideas?
Did you select the correct vehicle model in Calibrations > NAV? |
