Central Kansas | I have an ICU 95 code that comes up at startup on a 1996 JD 8300. The engine speeds up just a little and none of the gauges work, the corner post display doesn't work, the hydraulics do not work, and it doesn't go in gear. The owners manual says check fuse F1 which I did and everything was ok. I check some other fuses also and everything looks to be ok. This tractor did this one other time and we just shut it down and pulled F1 fuse and stuck it back it and then everything worked. Has anyone else experienced this problem? Is there something I'm overlooking, or is this a "dealer" fix? TIA | |
