Posted 1/29/2016 05:59 (#5071707 - in reply to #5071642) Subject: RE: Zinc sulfate in furrow
Northeastern Pa
I have a question I current put 1.5 pounds of actual z 2x2. In the form of zinc sulfate. Tissue test are still on the low side. Would it be better to double the amount of zinc sulfate (3lbs) or use cheltated zinc in my pop up. This is on high phos and acid 6.5 ph soils. TIA
