| So, you're after those last couple bushels? I would do what Clay and Jim said above, using the following parameters; 200 total lbs. N program, 1/3 upfront, is 67 lbs. At current pricing, 67 lbs. uan would be about $28. $28 will buy about 88 lbs. of urea. 5 gals. of 10-34-0 gonna run about $15 acre. That $15 will buy about 62 lbs. of MAP. Add 75 lbs. 21-0-0-24 to the mix. Blend the 3 together and impregnate your favorite pre herbicide, and broadcast spread yourself with a buggy, and incorporate in with your field cultivator. Everything is worked in, and not laying on top waiting for a rain to go to work. Planter free of all the plumbing. Life will be good.
Edited by Boone & Crockett 12/10/2015 06:00
