Rolla, ND | North Dakota is only worried that the scale is accurate, wouldn't want them to be off more than a bushel. After that, they can discount dollars a bushel and it's no problem. If you do complain and ask for federal grade, that usually goes to the guy that sells and services the machines for the elevators. Many of the machines used need to be regularly calibrated and the way the test isn't the actual test but a test that is related to the actual test. | |
