roaming | caseharvester - 7/26/2015 23:20
With 2 or more case combines in the same field, is it possible for the pro 700 to share lines so combines can follow each other through the field. What software/system do I need to achieve this. It seems like jD has a way to share lines between vehicles.
You can share lines between vehicles. You must use a USB stick to transfer lines. There is no wireless vehicle-to-vehicle transfer at this point. |
