Which cable (Pro 700 to Raven)
torn
Posted 3/6/2015 09:36 (#4435375 - in reply to #4435192)
Subject: RE: Which cable (Pro 700 to Raven)
roaming
tedbear - 3/6/2015 07:23
Are you positive that the Pro 700 is compatible with the Raven 660?
I am not familiar with the Pro 700 so it probably OK but I would check to be certain before I got into this project too deeply. The 660 uses a similar but different data stream then a 440 would. If the Pro 700 has a specific menu choice indicating 660 then things should be fine. If it only has a menu choice indicating 440 then there may be a problem.
Yes, the 700 is compatible with all of the 100 and 1000 series Raven serial rate controllers.
