Posted 2/13/2015 19:57 (#4383994 - in reply to #4383847) Subject: RE: '88 Ford L8000 Clutch Issues
Soil
A lot of heavy duty trucks have to have the clutch adjusted at the pressure plate . On the few that I have done, there is a 12 point bolt that faces the rear of the truck that has a lock ring around it that has to be pushed in then turn the bolt , by the way the clutch pedal has to be held down while you turn the bolt .
