Dearfield Co. | usually I measure the old ones for a starting pint. I also adjust it a little closer to the floor than the factory says just due to drivers hitting the bottom before the truck is stopped if its to far off the floor. Then make sure the clutch brake doesnt spin from the tabs being sheared off as that will make a different set of issues . If you can't measure it off the old ones to get close I think KW will have measurements for all of the linkage except what goes on the arm. I would say you will need to get the linkage rod thru the heim end about 1/4 inch so it is in mid adjustment without counting the lock nut
did you get the linkage from KW based on the Vin? it seems there is several sets of linkage to------------------------------I would readjust the stop all the way back and make sure the pedal is not sagging some throwing you off
Edited by a4t-1600 2/13/2015 18:33
