Posted 12/18/2014 16:51 (#4249266 - in reply to #4249147) Subject: RE: Movement detected opposite to command…..
mandan north Dakota
you need to adjust the steering over ride sensor, thy jerking the steering wheel when the autopilot is engaged if you do not get the warning the sensor needs to be adjusted
