South Africa; Free State;Vrede | Need your help please. I have a Raven Envizio Pro II that i want to use with a Arag electronic 7 section valve bank for section control. The problem is that the raven can not invert the current that the Arag valve bank needs to close the valve again. According to some experts i have two options: either put in a raven valve bank and change all the pipe fittings or get a inverter box to switch the current around to close the vlave again. Both is costing quite a bit. Is there not a more simpler way to invert the voltage? Apparently the trimble has a option to invert the voltage but the raven not? Any help please |
