South Africa | You will have to only input Gps into the NavII from the 500, and then connect the nav II to the fmx port c, to controll steering. (It is exactly the same as using a 252/262/372 as external reciever for steering with the fmx). You won't be using NMEA to the nav, it has to be TSIP, so i would just remove the CAN pins from the plug, (leaving the gps output from the 500 in) and put the can pins from the fmx in to the place of the 500.
Unfortunately I don't have the pinouts with me, but you should be able to find them in the manuals... | |
