Posted 7/30/2014 23:03 (#3994231 - in reply to #3992393) Subject: RE: 2366 rear main seal replacement
wc Ohio
Well I'm almost positive its the rear main seal as I added almost 3 gallons of engine oil last fall during harvest. Also the oil is black in color. Hydraulic oil level seems to stay up pretty good.
If I don't pull the engine will this make it much harder to remove and install the rear main seal, or is the only downside having to remove the PTO box and hyd pump?
