| thank you for your help hopefully i can get something figured out we definatley do have issues with signal because the base is 900mhz and is 8 miles away the base does have a booster on it and we did put a repeater on our leg which is one of the higher spots in the county for elevation so that helps but i do think we need to invest in a base all of our own. One thing im not sure of is we use all trimble for guidance and like tedbear was saying about geting those lines into each field do you export the lines and import them into SMS and then organize them into each field and export back out? the other thing i dont know is with our sprayer i think the track width is like 88.7' correct me if im wrong its a 4830 with 90' booms so if i made my master line 30' then i would shift it 14.35' right or not? thanks guys im learning a lot. | |
