Posted 8/1/2014 13:27 (#3996677 - in reply to #3993671) Subject: RE: 8230 distance calibrate
roaming
Lil' Hoss - 7/30/2014 17:41
There is one caviat to this, On a JD sprayer the wheel speed sensor must be calibrate for the radar (Whether radar gun or GPS radar) to operate correctly, the system uses wheel speed from 0 to 3 MPH and then radar takes over so it needs to be calibrated to know where 3 mph is. If the wheel speed sensor fails then radar will not start working.
Correct. I should have specified that my information was specific to the Case IH combines! :-)
