Pedee, Oregon | I wouldn't be afraid of the White. Slow hydraulics usually mean the suction screen is plugged. On the left side under the brake pedals there are a couple steel lines, one has a suction screen in it, 4 bolt square flange deal. Stainless screen in there, clean it good and put it back in. www.importtractorparts.net will tell you all about the models and parts availability. They are simple to work on and are very reliable. I have a 63' 2wd with 7,500 hrs on it that has been used hard and is still going strong. Some of the parts for the 4wd can be expensive or hard to find, but for what you want to do I doubt you'd ever have any problems. | |
