| How many weigh pins are on your planter and do you see much pin variance between rows when in same mellow soil
We had planter on concrete with blocks under gauge wheels in the shop been experimenting Zeroing pins then putting a known lb weight on to see if if weighs correctly,, trying to get known weight real reading.
Anybody try this as mentioned on page 37 to use formula of cal factor to get better readings? | |
