| Unless your ground is table top flat, I think you will need T2 due to the antenna height.
My 2388 has dual 20.8's, which I think may influence the settings and "turnability" of the machine. I ran the freeplay at 3.8, the angle/turn at 19, the aggressiveness at 135, and the header width at 28.5' (on 30' platform using WAAS).
I also found you could do better experimenting with the settings than doing the setup/calibration wizard. Good luck. | |
