NW Minnesota | Follow the positive cable from the batteries to the starter/alternator anywhere there is a "molded" joint could be an issue, we had issues with our 9680, not charging, and not starting after checking the alternator, starter and batteries, did some checking with the voltmeter and found varying voltages so I pulled the main power cable from the tractor. Where there was a molded "T" in the harness that connection had failed and was full of corrosion. The truck shop made me up two new cables to eliminate the "T" no problems since. | |
