Posted 12/6/2013 18:09 (#3496733 - in reply to #3495674) Subject: RE: What is more important ~
iseedit
I think your views of the critical nature of spools bolsters my entire thought on just buying a "factory reman" gang assy.
I can tell you that a "bolt" (JD parts info) that is heated will break at the heated point. After spending the hundreds of dollars for blades, scrapers, bearings, etc, still the cost of the bolt is minimal.
