Ea. Washington | Won't be much stuff hanging on the walls made out of OSB. Probably will fall off by the time it needs painting. Spend the money for plywood, you won't regret it. Use T&G 3/4" flooring underlayment. Looks fine when painted. Screw the stuff on the walls, doesn't take long to unscrew with an impact driver and you can fasten it back with the same screws in the same holes. What really works best is to not get the walls dirty to start with. JMHO. | |
