WCOH | It produces what is needed. You can hook a 60w bulb to a 12kw generator and it produces 60w. The 'extra' juice doesn't 'go' anywhere cause there is no extra, just the potential to produce more. If you used all 12kw it takes alot more hp to run. Think of it this way, a common household 110v circuit is 20A. If the only thing plugged into that circuit draws 100w, then that's all is draws, the 'extra' amps don't have to find somewhere to 'go' because there aren't any. If this statement makes no sense to you call an electrician. | |
