Dallas Center IA 515-720-2463 | Trust me, back in the 1950s and 60s there was far more plowing at under 4 mph than over 5 mph.
Probably figuring wheel slip in more at under 4 than over 4-1/2.
May me going out on a limb here , but I would even think more under 4 than over 4.
The no load ground speed of a two cylinder Deere was under 4 mph.
True you can us horsepower with less weight by plowing faster.
Something else to consider, rocks hit at 4 mph will do a lot lest damage than hitting one at 5 mph.
Also trash will flow thru better at lower speeds.
Many cannot believe how big a plow a tractor would pull for the HP per bottom.
Like a Deere 70 had about 12 HP per bottom.
Speed tells it all.
(MVC-006S (Medium).jpg)
Attachments ---------------- MVC-006S (Medium).jpg (98KB - 406 downloads)
