Nc Ks. | Our JD baler does that on our JD tractors. I've got a 5ft. pry bar with a slight flat bend on the end. Get that between the pto housing on the tractor and the end of the baler shaft. Works about as good as anything I've found. Keep the pto splines lubed good before coupling helps. Neighbor bought a used swather and couldn't unhook it after the first trip to the field. JD mechanic came out and had a heck of time. After they got it off, discovered the splines inside the pto pump of the swather were shot. Good luck. | |
