Ohio | Rotary straw sucks period. Why do you see ads wanting conventional straw? You leave some in the field because the baler can't pick up everything with it being so fine. I recommend a conventional Deere. Either a good 20 series which are hard to find or a 9000/9010 series. Since you are used to conventional straw from your 715 I'm willing to bet you won't like the rotary straw. I don't notice any absorbing difference between the 2. Do you use round bales? If so you won't be rolling them around the pen anymore to unroll/spread them. You cut the net wrap on a rotary round bale and all you have is a big blob.
Edited by EAckerman 11/15/2012 22:14
