Davenport, Washington | Tommy is technically correct. I would also believe that the door sticker is based on that formula on an average load. That would change if lots of stuff is loaded in the trunk or on the bed. However for me it seems that if I have uneven tire wear, it will always be the edge rather than the center. So I run on the higher side or max tire pressure. My tires lose pressure before I check it again anyway. | |
