NE Colorado | Our JD S670 combine, 612C head with contour option, running a GS3 is recording data only when using the 3 button on the handle in the the field. Have a defined exterior boundary and swath control running which both seem to be working. Tried changing the stop height and did not help. The only option to manually raise and lower the head in the field to keep the recording from stopping is turning the ahc dial on the console. If we use the raise lower button recording will stop and create a skip until the 3 button is touched again. Any suggestions would be greatly appreciated. Updated Apex on 9-22 and then reloaded the data as the variety locator was not working before this. | |
