New Iberia la (Cajun country) | Ok so my engine pressure sensor went off and when I turned off the machine I noticed the blower.motor was still on with the key off. So I unPlug the pressure sensor ( the one under the manual fuel pump) and the blower motor turns off Inside the cab . I leave it unplugged, start the motor, engage everything And none of the controls work on the joystick. So I turn off the machine plug the sensor back in and the alarm goes. Back on but everything works on the joystick. Is this a relay or something like that ? Maybe the sensor? Please help 35 acres to. Cut with 50 percent rain tomorrow. |
