Search Forums | Classifieds (18) | Skins | Language
Brown Box "Offset" Question
JK SCLA
Posted 7/1/2012 15:14 (#2460426 - in reply to #2460142)
Subject: Re: Brown Box "Offset" Question
When you put a value in the offset column, there will be a toggle to place the offset on whichever side you need it on. If value is set at zero, then you will see the implement is centered. Put in a value and you can toggle right or left. I have two tools that I have to run with an offset, change it frequently. Also, you can do this on the go and shift track or re-center track if it is not what you like until you get it figured out.
