Centre county Pennsylvania, USA | Baud rate determines the signal bandwidth of a connection, bit rate determines it's information rate. Because most GPS receivers are encoded for 1 bit per baud, their bit rate is same as their baud rate as Lance has explained above. However; most of today's modems encode more than one bit per baud, thus achieving connections with bit rates greater than their baud rates. |
