| Funny seeing problem with ring tones. That was my second big problem
with HTC this fall. The problems, signals and dropped calls have now made
the press. I guess I wasn't the only one.
As for ring tone I figure out two problems with HTC. first if you pull
it out of pocket by the face and finger slip up it tells phone to ignore
call. If you place you fingers on the side you can turn off ringer. Then to
top it off it screwed up the tone to single low beep. Was going to take it
back but changed the ringtone then changed it back, which gave my the old
ringtone again.
(rubber protector doesn't help keeping finger off button as button is near
top)
