Bourbon, Indiana | I"m in the process of installing a (outdated) PF3000 yield monitor in my combine and it says to set the C11 number to whats on the sheet that I have and it will change the other C#'s to the correct value, well I did that and their not the right numbers on the sheet. So I set the C11 number where its suppose to be and manually changed the other C numbers to the value on the sheet. Is this the correct step or did I screw it up?
thanx | |
