Posted 9/25/2011 15:44 (#1978284 - in reply to #1977931) Subject: RE: ag leader 3000
The PF3000 PRO (Later the Advantage) does use the AUX 1 port (15 Pin). The regular PF3000 uses the 9 pin connector. The wiring for this connector is the same for a YM2000, PF3000, Insight, Integra or Edge.
The PF3000 Pro and Advantage are the only two models that use the 15 Pin connector.
