roaming | nevinstobbe - 9/20/2011 09:04
Also in the crop type the first time you open the drop box it displays a crop that I have filtered out already, the second time you open it it's not there like it should be.
That's normal. The crop type that "shouldn't" be there is already assigned to the existing Task, so it shows up in the picklist. Also, if you have already harvested crop under a certain Crop Type, I don't think you can filter it out.
You can see what I'm talking about if you unfilter all crop types, then go to Performance > Profile, create a new Task and select Corn as your Crop Type for the Task. Then go back to Data Management > Filter and hide Corn. Go back to Perf > Profile and Corn will still be selected, because it was already assigned as the Crop Type for the Task. It will be in the picklist when you open it up, but if you choose some other crop from the picklist, then Corn is no longer needed/assigned, and so the filter can actually hide it. |
