Near Intersection of I-35 & I-90 Southern Mn. | It can be done.
First the files do need to be .ref files.
Second I'm not sure if a trial version will work as we've always used a "real version"
Third with a 20/20 I believe that there is a step where you must associate a crop type (Corn for example) with the file. If you don't, the file appears in the list on the Integra but it won't be "brought in".
If you look below, there is a post that outlines the basic steps for a PRO 600.
1. Make sure SMS is up to date.
2. Press the Device Setup Utility button on the top bar.
3. Click Add New
4. Enter a Name
5. Select the Grower (or Farms/Fields) that you have As-planted maps for
6. Skip Resource Tracking
7. Skip Pest Setup
8. Skip Product Setup
9. The Spatial Data Setup page is the page we care about. We need to scroll down and find either Site Verification or Planting (or whatever the Pro600 considers As-planted maps to be) and ADD that line to the right hand column
10. Click Finish
11. Export to Display----> Integra
12. Done!
Edited by tedbear 8/24/2011 07:32
