Texas | Depends upon which model you have. If you have wifi only then you will need to have a network at home or wherever you are using it.
If you have the one with the cellular modem, then you can subscribe and use the AT&T cellular network wherever it's available to access the internet.
Check to determine which one you have and then you will know your options. |
