Yorkshire UK | ronshir - 9/22/2010 20:33 I have a AMD Athlon 64 ,3400+, 2,19 GHz,448 mb of ram. It is slow. Any ideas? Barely enough to run XP when you have a few other things installed. If you can increase the RAM it would help, more dramatic and brave solution would be re-install the system from recovery discs if you have them. Quite a lot of work backing up and setting up again but will give good results longer term.
