Posted 3/26/2024 09:57 (#10680959 - in reply to #10680176) Subject: RE: Hagie 2100 wheel motor leak update and questions
North Iowa
The pilot o-ring won't be part of the motor seal kit provided by Danfoss. It needs to be ordered separately . Depending on what the motor is mounted to can require use of different o-rings by the OEM. Agree with others that symptoms of failed shaft seal are over-filled gearboxes. Need to find source of external leak.
