![](/profile/get-photo.asp?memberid=46415&type=profile&rnd=312) NS Canada | Quick air exhaust valve arrived, and I put it in, now instead of never getting air, It wont stop sending air to the bead blast assembly.
Blue line comes from main air feed, it Tees off and feeds the on board tank as well as the dump valve, which should have air at the ready for when the bead blast pedal is pressed. Red line goes back to air chuck for filling tires, its working as it should.
Black line goes to the dump valve and should control the air to the bead blast, there's no pressure on this line, so it seems as if operating it, releases pressure to trip the dump valve?
1 pedal controls 2 valves, a half press for filling tires, full press for adding bead blast air.
I don't believe I have the valve in backwards, just based on how the spring is held in it. But cant figure out why it wont stop by passing air.
(20210521_120740 (full).jpg)
(20210521_120800 (full).jpg)
Attachments ----------------
20210521_120740 (full).jpg (131KB - 79 downloads)
20210521_120800 (full).jpg (92KB - 86 downloads)
