Case IH Farmall 105U PTO Speed Doesn't Change
CaseIH2388
Posted 3/11/2021 18:35 (#8886622)
Subject: Case IH Farmall 105U PTO Speed Doesn't Change
Strasburg North Dakota
Have a 105u that the pto speed doesn't change when you swap out the shafts. It's in 540 with the 540 shaft in but when you put the 1000 shaft in it still only goes 540 rpm. I looked at the parts diagram and there is a plunger, lever, fork and a collar that changes changes between the two gears. Anyone have any ideas what fails before I dig into it?
Edited by CaseIH2388 3/11/2021 18:45
