South Central South Dakota | We got a JD 6155R this summer with IVT transmission. Primary use is as loader tractor for loading feeder wagon. My question is, is there a right or wrong spot to have the throttle will using? I've heard some have it wide open and leave the shifter in one spot and some basically at idle and move the shifter to speed up and slow down. I've tried both and I think I like it abour right in the middle and leave the shifter right at the top of low range and move it a little either way. So is there a right or wrong way to use it? Thanks |
