Search Forums | Classifieds (33) | Skins | Language
JD 8370RT Fuel Gauge
KT1
Posted 1/23/2021 16:13 (#8775235)
Subject: JD 8370RT Fuel Gauge
SE Iowa
Fuel gauge is giving trouble on an 8370RT. When you turn key power on or start the tractor, the gauge on the corner post does the following:
1. All white bars light up for a couple seconds
2. Correct fuel level lights up for a couple seconds
3. All white bars go dark and stay dark and the "Percent of Fuel" on the GS4 screen shows "---"
New sending unit was tried on the right fuel tank and problems stayed the same.
Is it the sending unit on the tank under the cab or another problem? TIA
