Search Forums | Classifieds (5) | Skins | Language
T6050 Plus 16x16 Transmission Problem
SJordan
Posted 11/25/2020 15:41 (#8624261)
Subject: T6050 Plus 16x16 Transmission Problem
We have a 2011 T6050 Plus with 5000hrs and a 16*16 Electroshift transmission that is giving us some problems. A few days ago was unable to use gears 9,13 and 15 all other gears worked as they should. We recalibrated the the transmission with the oil warm, and all clutch packs calibrated clutches 1-3 were roughly 200-220 and C4 was 460. After calibration the problem persisted. Today all gear 1,3,5,7,9,11,13 and 15 will not work and we can no longer calibrate the C4 clutch pack and get a error code of U30 when calibrating it. We tried swapping the C3 and C4 solenoids as they are never utilized in the same gear. The problem remained the same. Leading me to believe that the C4 clutch pack is bad. Any other suggestions, we are pretty mechanically inclined and have a nice shop to work on it. Any one else replace that clutch pack? Big job? Also does any one happen to have a digital copy of the service manual for a T6000 series tractor or a Maximum series?
Thanks,
Spencer
